Mirror rigging? (solved)
felisfelis Posts: 6,553
If you have created bones in one side, is there then a way to mirror the bones to the other side?
There was some discussion of rigging an elf ear. So I thought, let me try that.
I added 2 extra bones for the left ear (a geocraft), and did some weight editing, and it worked. Could have been better, but for the purpose is was good.
So I thought, how can I mirror that to the other ear. In weight paint there is a symmetrice option, but I couldn't find anything similar for bones.
So how do you create mirrored bones for left and right?
Post edited by felis on
  • Richard HaseltineRichard Haseltine Posts: 111,715
    edited April 2022
    If your bones are named to match, and have a prefix (e.g. l and r) to indicate which side they are on then, with the Joint Editor active, select the first of ther ones you have rigged, right-click>Edit>Mirror Joints..., select the appropriate option for direction and Selected recursive for Nodes. Weights can also be mirrored, as long as the mesh is symmetrical.
  • felisfelis Posts: 6,553
    Thank ypu - I had overlooked that option.
    But I still have an issue.
    I would assume that it should work if I call it "Left_ear_2" (etc.), but with the attached settings nothing happens.
    828 x 490 - 267K
    What are the bones called? The name of the right one matters too, it must be the same aside from the prefix.
    I misunderstood.
    I thought it could mirror, as in create, but it mirror as in transfer values. Now the options also make more sense.
