How to disable lites in 1920-city-street
VicSVicS Posts: 1,273
edited April 2022 in Daz Studio Discussion
I just started using [1920-city-street] this, there is a button for street emissive off but all those big  lights are still on and they make the render impossible top complete free of noise,
Anyhting I searched for in the scene tab didnt lead to finding the lites to turn offs there a standard way to disable the lights in thid or any set in general?
thanks
https://www.daz3d.com/1920-city-street
Edited for Please put your question in the post body and the title - Daz 3D Forums
Post edited by VicS on
  • Richard HaseltineRichard Haseltine Posts: 111,867
    Adding lights usually removes noise, as you aren't waiting as long for light to bounce into the awkward corners. That said, if I select the light the preset turns them off - it isn't a hierarchcial preset to do everything in one operation.
    Do please note Please put your question in the post body and the title - Daz 3D Forums
  • VicSVicS Posts: 1,273
    Richard,  youre saying there is no easy way really  to find all lites so they can all be disabled in surfaces?
    The street lamps are in named groups for each section in the Scene pane - for example CS Street Building group A contains CS Street Lamp Group A, which contains the five lamp posts.
    Thanks Richard, there are stil llites on, I checked I have turned all the lites in the scene off
    As for the lite manager pro what what shall I do to disable the lites in there? Mine remian on after uncheecking all in the first image-didnt know what to try in the tab in second image
    thanks
    1580 x 1969 - 4M
    2675 x 1828 - 2M
    2917 x 1827 - 3M
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,749
    edited May 2022
    if you select one emissive surface with the surface selector you can rightclick and use the the option to select all surfaces with properties choose emission value then in suface tab edit them at once
    Great tip Wendy, thanks a lot
