Collapse Group
I have developed a script that will loop through a large number of objects and apply a material.
That part works fine.
The problem is that after the script has executed, the scene shows all my groups that I created objects in expanded and selected.
I made a loop that deselects.
Now I am looking for code that will allow my parent object to collapse in the Scene tab.
The following calls don't seem to work:
MyObject.select(); // Iselect the object first
MyObject.setCollapsed(); // In documentation but does throws an error
MyObject.closeSelected(); // Does not seem to do anything
Also is there a nice easy way of unselecting all objects in a scene programatically and collapsing the open structures to root nodes?
Post edited by FasterScene on
  • OmnifluxOmniflux Posts: 442
    Scene.selectAllNodes (false);
    Then, select only your root object(s) to collapse and call
    MainWindow.getPaneMgr().findPane ('DzHierarchyPane').closeSelected();
     or, to collapse everything
    MainWindow.getPaneMgr().findPane ('DzHierarchyPane').closeAll();
  • FasterSceneFasterScene Posts: 8
    edited April 2022
    Oh yeh Omniflux!
    That's much neater!!
    Thank you
  • Richard HaseltineRichard Haseltine Posts: 112,197
    Just bear in mind that these are not official, documented methods so they may be changed or removed without notice.
