DAZ
n.jmurovn.jmurov Posts: 91
If I have scanned a person using photogrammetry tools, is it somehow possible to use the mesh to create a morph on an existing DAZ figure? e.g. in ZBrush. Many thanks.
  • Cris PalominoCris Palomino Posts: 13,053
    With scanned data, you would have to clean it up. You would likely ZRemesh it to get better topology. However, in any case, it would be new geometry and you would not be able to use it on a DAZ figure as you cannot change the vertex order of the model and have it work. Any addition or deletion of mesh on the DAZ figure would change it. The most you could do, especially if you aren't a seasoned ZB user, is use the mesh as reference for you to morph the DAZ figure's mesh.
  • n.jmurovn.jmurov Posts: 91
    Thanks for the info, Chris. How is it possible for tools like Facegen to create DAZ-compatible morphs?
    I can't speak to how since I do not use it, however, i can only imagine, to be able to use with DAZ Studio, they'd have to adhere to the same guidelines that morph the DAZ figure mesh.
