Recompille
hello, i have a weird problem.
Daz does not recognize my video card (even if its there my Advanced simulation setting), its says i need recompille the video card.
HOW?
Thank you
Sade
  • felisfelis Posts: 6,498
    That happens to me (I think) if I have updated drivers.
    But as I remember it comes up with a box where you can click 'Accept' or something.
  • SadeSade Posts: 883
    it didnt popped up any box. i didnt update the driver, but it would work, if i downgrade?
    Hmm ...
    Have you made any known changes recently?
    Beside Daz Studio, does it work for everything else?
    When do you get this message?
    if i want use dforce, its freeze the daz after 15%
    i reinstalled the driver, but nothing changed
    everything else is works, and recognize my card
    its super frustating :(
    So you can render, but not use dForce?
    And if so can you then use dForce on the CPU?
    Its have only my videocard at the dropdown menu. How can i dforce with cpu? Thank you
    If I go to Simulation Settings > Advanced I can choose either my GPU or my CPU, although the CPU is much slower.
    Even though that you have tried to change driver, it seems to me that it is a driver issue.
    Exactly when does Daz Studio come with the notification that it must be compiled?
    when the error was first pop up. i allowed to do, didnt change nothing.
    the dropdown menu allow only videocard..probably my cpu not enough good? dont know.
     i try reinstall everything
  • SpaciousSpacious Posts: 481
    Maybe try installing an older GPU driver?  Then run a simulation, and if it works, great, you're done.  Or you could even try to install the newer driver after that again, since it would then have to recompile.
    Thank you! I made a windows built in driver rollback reinstalled drivers, daz (both version what i have), went back a previous windows save point what is finally solved. Was superweird experience. Thank you for your help!! <3
