• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
How do I fix clothes pop in?
lou618_2b45855fe7lou618_2b45855fe7 Posts: 65
March 2022 in Blender Discussion
frown So I just imported a scene into Blender from Daz Studio, but clothes are still popping in through the models, not fitting as intended. How do I fix this in Blender? is there a demorph type of tool in Blender? How do I select the bones of the clothes?
  • juvesatrianijuvesatriani Posts: 561
    March 2022 edited March 2022
    You can fix them using SCULPT tool . As long you`re not bring back those model into DAZ studio again , you can literally use any sculpt tools to fix it .
    Here the simple walkthorugh ,
    • Open plus sign like outliner just like you find or select conformed/parented object in DAZ scene tab
    • Find and select the clothes object ( make sure you`re still in OBJECT mode not EDIT - SCULPT or POSE etc )
    • With object selected change OBJECT MODE into SCULPT mode  , the left area will changes with bunches of SCULPT Tools
    • Choose GRAB sculpt tool , then try use it in area you want to fix
    • Play with RADIUS - STRENGTH _ FALL OFF setting for more precise with your need
    • Back to Object Mode if you`re done .
    Optional : save it as new custom shape key ( Custom morph if in DAZ ) . Find tutorial in youtube for create new Shape key
    Post edited by juvesatriani on March 2022
  • PadonePadone Posts: 4,372
    If you use diffeomorphic it bakes from the viewport so you get "pops" only if they are in daz studio to start with. In which case you can either fix them in daz studio first or in blender as @juvesatriani explains.
    Post edited by Padone on March 2022
  • lou618_2b45855fe7lou618_2b45855fe7 Posts: 65
    March 2022
    smiley It's working, thanks.
    March 2022
    Yeah, I'm using diffeomorphic actually. It usually does a really good job transferring the scene exactly as you left it in Daz Studio. It just didn't exactly workout this time.
    smiley Man, this sculpt tool works even better than the deformer tool in Daz Studio, WAY better. I really need Blender in my life man.
    Post edited by lou618_2b45855fe7 on March 2022
    Yeah, I'm using diffeomorphic actually .. It just didn't exactly workout this time.
    If there's any smoothing be sure interactive update is on otherwise it won't be exported. But you can also use a shrinkwrap in blender instead that's usually better.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/226/importing-the-daz-smoothing-modifier
    440 x 128 - 18K
  • SDevSDev Posts: 158
    April 2022
    I would add a new shape key in Blender first before start sculpting. I use mostly the grab and elastic deform brush while working on the base mesh.
    Small tip: If you can't rename a shape key or a vertex group name, just switch off any subdiv modifier in viewport. Then renaming works again :)
  • Raitan2008Raitan2008 Posts: 27
    April 2022 edited April 2022
    I just select the mesh, go into edit mode, select the vertices that are poking through, assign them to a new group and name the group. Then I go to object mode and add a mask modifier. Choose the new group as the vertices you want to mask and invert it. Boom. NO poke through. In fact, if the clothes cover most of the body, I automatically hide almost all vertices just to be sure. I used to delete the vertices, but that causes more problems that it is worth...masking is better.
    Post edited by Richard Haseltine on April 2022
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
