Thinner Torus ?
Ok so im making a portal with a torus.
But its pretty thick and i want to reduce the diameter.
How to i do it ?
also how do i get it perfectly round and not jaggy ?
thanks
2560 x 1440 - 3M
  • barbultbarbult Posts: 27,678
    edited March 2022
    When you creat the torus, you specify the major and minor diameter. Adjust those to make the torus as thick or thin as you like. If by thin you mean what I would call "flatter", adjust the Scale X, Y, or Z as approptiate in the Parametes pane,
    To make it smooth and round, add subdivision.
    Post edited by barbult on
  • Thanks Barbult.
    So yes it worked when i created the torus. made it thin like a hula hoop.
    now i just have to find the subdivision parameters.
  • Select the torus > go to Edit > Object >  Geometry > convert to SubD...
    In the Parameters tab with the torus still selected go to General > Mesh Resolution and set the slider RenderSubD Level to your likeness. But in the most cases you will be fine with 1.
