Surfaces/Opacity
In the latest version of DS, it appears that in the surfaces tab you cannot select individual surfaces and then change their opacity.   The control panel for this it appears has been removed.  Is this correct, or are there other plaves to see this. If you select the whole object, you can see these seetings. But if you want to do something like turn the opacity to zero on the belt loops, or sleeves, or other subdivided surface, DS doesn't allow you to do this. Are those controls somewhere else?
  • felisfelis Posts: 6,504
    In Iray you have 'Cutout oppacity' in the surface panel for oppacity controle.
  • IceCrMnIceCrMn Posts: 2,333
    Not every item of clothing is setup the same.
    Some don't have separate surfaces for the belt loops, or sleeves.
    The Surfaces pane is what you are looking for to control these settings.
  • If you look at the Surfaces Tab/Pane on this version of DS, there is a list of all of the surface subcategories if you hit all. When you select ANY individual surface, all of your ability to customize the fields is missing. Is there a setting I am missing so I can see my surface sub-settings.  In this one, I want to change the lower sleeve (a separate surface) to zero, yet the option menu is missing.
    468 x 473 - 57K
    468 x 473 - 49K
    yes,
    Check the "Show sub items" box.
