Is there a way to raise or lower a hem?
HonzoHonzo Posts: 193
edited March 2022 in New Users
[Is there a way to raise or lower a hem?] Other than going to Blender, I mean. Is there some basic utility for this kind of thing?
Edited for Please put your question in the post body and the title - Daz 3D Forums
  • Richard HaseltineRichard Haseltine Posts: 111,716
    A dForm could do it fairly simply - select the item with the hem, Create>New dFormer, adjust th field so that the bottom of the hemmed item is in the middle and the top is, say, about waist level (you want to spread the adjustment over as wide an area as possible while trying to avoid moving the bend points) and move the actual dForm node up to raise the hem.
  • HonzoHonzo Posts: 193
    Thank you! That seems pretty straightforward for DAZ...
  • QuixotryQuixotry Posts: 919
    There's also dForce as a method if you can use it. I have this old tutorial in my gallery on how to lengthen a skirt with dForce. It's based on simply adjusting the contraction-expansion value for the relevant material zones on the skirt, and can be done in reverse to make the skirt shorter. Higher values in the contraction-expansion setting make it longer, lower values would make it shorter.
    Use dForce to Make a Short Skirt Longer
    Or one could scale the height of the pelvis, thigh and shin bones.
    Thanks, all of you. I'll give these methods a shot.
