How to Add A head of One Character with body of Another?
souravpadhi89souravpadhi89 Posts: 80
edited March 2022 in The Commons
Hi,
I have 2 figures: Genesis 8 Male and Ape World Gorilla for Genesis 8 Male.
I want to attach the Head of the Gorilla with the Body of Genesis 8 Male.
Is it possible? Please note the Gorilla Dials change the complete body and has no separate dial for head.
Thanks!
Post edited by souravpadhi89 on
  • Matt_CastleMatt_Castle Posts: 3,251
    While there are tools that can split morphs into different body parts, I'm not going to recommend them here, as I don't believe the results will be satisfactory. It's a very heavy morph (which don't split well) and presumably with an HD component (which cannot be split by end users), so I think that what you want to do is for practical purposes impossible.
  • functionfunction Posts: 285
    Maybe you can try this (Shape Splitter), and let us know if it works.
    Okay, Sad :(
    Thanks, but will it work on Genesis 8 figureS?
    yes, I have used it a few times and it worked great for my uses. besides, if it doesn't work for you, there is a return policy
  • lou_harperlou_harper Posts: 1,163
    Since they are both G8 models shouldn't you be able to dial the body and head separately? The fur would be an issue I assume, but rendering twice and compositing in photoshop could work.
    Rawart doesn't usually have seperate head and body morphs for his products
  • JOdelJOdel Posts: 6,322
    edited March 2022
    If it's for a still image you can kitbash two seperate figures. A lot will depend on how you conceal the join.
    And postwork is your friend.
    Post edited by JOdel on
    If for a still image you can do two renders, one with the ape and the other with G8 in the same position and then combine them in Photoshop.
  • eeyuneeyun Posts: 53
    Alternatively, check out Richard's comment in https://www.daz3d.com/forums/discussion/554206/the-parting-of-the-lips
    The headsplit deformer and Morph Loader Pro import / Attenuate By / dForm was news to me.
  • FauvistFauvist Posts: 2,290
    I use heads from different generations of figures ALL THE TIME.  If there's no separate head and body on a figure, try the SURFACES pane - it may be able to make the head or body invisible - I believe the slider is OPACITY CUTOUT or something similar.  I have also got rid of a body by scaleing each body part to 1% - so that the entire body I want to hide disappears inside the body of the body I DO want to use.  I don't buy figures anymore that have restrictions on them - like NO separate sliders dividing the head from the body.
  • kyoto kidkyoto kid Posts: 42,408
    ....did it long ago with Sadie and Aiko3
  • CricketCricket Posts: 501
    If you just want the head of the gorilla, you could use Gorilla for G8M; assuming that has sepearte head and body morphs. I don't have it myself, but the old one for G1 did.
