My saved custom workspace layout is not showing in the select dialog ?
Hi, I am setting up, and saving my workspace, and everything is going well - give it a name, and saving, all ok. But it is not showing in the layout meny, anyone ?
I am running Daz.20 on a Macbook pro :)
This is a known issue with 4.20.0.2, the Public Build has a fix.
Hi Richard, thanks for your reply, maybe you could point me to the public build solution, I have searched for an update to version 4.20.0.3 as I understand that this will do the trick, but can not find where I can download it, if this is the solution you are pointing to?
The Public Build is the beta - it's free but, if you haven't yet done so, does have to be purchased from the store https://www.daz3d.com/daz-studio-beta . Once you have it it it is a separate isntallation from the General release, and has to be installed through Install Manager (not manually or through Daz Central) https://www.daz3d.com/get_install_manager/
There should be an update to the General Release, assuming there are no sudden issues with the beta, early in the week.
Yes, I have installed the public build, like you said, version 4.20.0.2 but there is no update to that, I assume I would find the update in the preference menu, but it says that no updates were found, I will check again later, and see if it will be available :) Thank you again, appreciate your help.
The update, 4.20.0.3, was released on Thursday.
Hi Richard, What I did not realize, was that the public build was installed as a separate app, I used my old shortcut, and off cause get the 4.20.0.2 and not the 4.20.0.3. Got it now, Thank you again
