someday - ERC Tricks - ( post includes code for nerds )
i must return to the midi animation project
so this wont be available right now
but
sometimes i animate Amy's head using mcjKeepOrient
this keeps her had still while the rest of the body moves, a walk or a dance
this means there's 1 keyframe per animation frame imposed on the head node
but during the walk i'd like her attention to turn to the camera or the road or things
so how do i mix the two ?
by adding a second head joint
using an ERC Link and a gizmo
the gizmo's rotations are added to the head rotations
in the gif below, the gizmo animation is a slow Bend/Unbend
and Amy's initial head animation is a fast head bobbing
if you know daz script programming, here's the script i used
you can also see i did a quick rigging of the Mitsu hair
another advantage of this system is that i could reserve the head node for morph/lipsync keyframes
and have all the head rotation keyframes on the gizmo
it would be easier on the DS Timeline to keep track of what's going on
note the precise sinewave animation curves were created using mcjCycleFilter
https://www.youtube.com/watch?v=4rcAHyf0lxs
// DAZ Studio version 3.0 filetype DAZ Script
//uninstall()
install1()
//install2()
function install1()
var masterNode = Scene.findNodeByLabel( "mcjGizmo3" );
var slaveNode = Scene.findNodeByLabel( "Amy" ).findBone("head");
var slaveProp = slaveNode.getXRotControl();
var masterProp = masterNode.getXRotControl();
var oERCLink = new DzERCLink( masterProp );
slaveProp.insertController( oERCLink );
function install2()
var masterNode = Scene.findNodeByLabel( "Amy" ).findBone("head");
var slaveNode = Scene.findNodeByLabel( "AmyHair" );
var slaveProp = slaveNode.getObject().findModifier( "NeckFwd2" ).getValueChannel();
debug( slaveProp.getLabel() )
function uninstall()
var ctls = slaveProp.getControllerList();
if( ctls.length > 0 )
if( ctls[0].getCurrentProperty().getOwner().name == "mcjGizmo3" );
slaveProp.removeController( ctls[0] )
