Rig an ibex obj file like the Daz Originals' s Buck model
bondwebbondweb Posts: 27
edited February 2022 in Daz Studio Discussion
I there I got an ibex obj file and I wanna to rig it using the same bones architecture of the Daz Originals' s Buck model.
Can anyone help me to do it? I can pay for that
Thanks guys
  • felisfelis Posts: 6,583
    If your model is around the same size, you could use the transfer utikity.
  • LeanaLeana Posts: 13,616
    Which buck are you talking about? This one? https://www.daz3d.com/buck
    It's a legacy figure rigged for Poser, so transfer utility wouldn't work.
  • Let's go with weight mapping ;-) Morphs etc then are possible. Legacy not so much.
    These tutorials were made a few years ago, I think the main difference was a tool being renamed to Geometry Editor but they are still quite followable:
    https://www.daz3d.com/rigging-original-figures-in-ds4-pro  Excellent place to start, explanations, etc.
    https://www.daz3d.com/advanced-rigging-in-daz-studio-4-pro
    https://www.daz3d.com/rigidity-grouping-and-mapping-in-ds-4-5
    Yes it is. I tried to transfer the buck bones to my ibex obj but it doesn't work. All the bones have a very small size how you can se in my attach
    1920 x 1080 - 223K
    Are you talking about the figure set up window?
    1920 x 1080 - 214K
    Usually there's a big sale in March called March Madness, these days though who knows whether it will be or not.
    wow did the forum bug ever go nuts, maybe a nice mod will clean up the duplicate posts.
    Post edited by Catherine3678ab on
  • using horse3 might give better transfer Utility results but you ibex needs ti be imported to scale and the same position as it.
    I can't delete them
    Thanks I will try becouse with buck the transfer utility kit doesn't works, probably the model legacy block it
    I tried I think so, the transfer doesn't works
  • Moved to Daz Studio Discussion as it is not a Product Suggestion.
    I can't delete them
    I know, that's why I used the word "mod" - that is an abbreviation for "moderator" in here. And one did ;-)
    IF you change the legacy figure's rigging to weight mapping {one of the edit options} then you might be able to transfer the rigging to the ibex.
