DForce Help needed
Hi -
I have no idea how to correct this. I am using the animation timeline when I run DForce. Once it gets my character in position, the character moves up from the couch as the skirt settles. This makes no sense to me.
Thanks -
544 x 576 - 219K
  • charlescharles Posts: 866
    edited February 2022
    Is in Simulation Settings, Start Bones from Memorized Pose, on?
    Try turning that off. If you need it to be on, then check the hip location, you may need to zero it out and realign the character. After you zero it out might be a good idea to set that to the new memorized pose.
    Post edited by charles on
  • KeithHKeithH Posts: 338
    It is set to zero and no I did not have the from memorized pose on.
    This is first time I have had this happen.
    Thanks
    1920 x 1050 - 519K
    I tried another couch and got the same result. Just in case I changed something from the default dettings on the skirt, I  deleted and readded it and same result.
    Is it a keyframe that brings the character up? Check the timeline?
  • So what is her position in the final frame before you simulate?
    I deleted the dress and character. I readded them and all works fine. I would love to know what happened to make her lift from the couch like that.
    Her final position was on fram 30 and should have settled only through frame 90. Once in position it would push her up suring when it should of been settling.
