Library
How do I move the highlighted folder so that it resides under DAZ Studio Formats and NOT under it's current location?
I seem to have several instances of this happening in the hieracy
341 x 432 - 22K
  • TogireTogire Posts: 459
    This asset has been incorrectly installed. Assets from other vendor sites may be located under a directory named 'My Library' like this one (but other top level directiry names can be found). When you install them, you must copy the *content* of this top level directory to the actual location of your library.
    The simpler is to suppress this directory and to install its subdirs (probably Data, Runtime and People) under your daz library.
  • That looks like a bad product package - you should not be seeing the my Library folder there at all, nor the data tree under it.
    How are your content libraries set up in Content Directory Manager?
    564 x 532 - 60K
    384 x 240 - 19K
    469 x 311 - 24K
    No problems there.
    Must be the path that's specified in the installer (DIM or DAZ Central)
