Opaque highlights
MGMOZMGMOZ Posts: 108
G'day there all,
I hopefully want to be able to adjust this particular settling in DAZ3D 4.7.
When I hover the mouse over an object within a scene, it becomes opaque yellow and I can't see the other objects within the area of that object.
An example would be a character leaning against a wall. I, for instance, want to slightly move that wall in relation to the character. With the mouse highlighting this wall, I can no longer see the character & it is trial & error to do the adjustment because I can't actually see this character.
Yes, I can do this adjustment via the Parameters tab but there are times when this highlight 100% opacity is a nuisance.
I want to be able to adjust the opacity strength so that I can still see other components in the highlighted area.
Does that make sense?
Any suggestions?
Post edited by MGMOZ on
  • edited December 1969
    There's the sort of solution of closing the eye of the object that is being a nuisance in scene tab.
  • MGMOZMGMOZ Posts: 108
    Yes, but that defeats the purpose.
    The main time it is the problem is when you revolve a scene to get a better view of a particular object that you want to fine tune. Turning off the view of the object is counterproductive.
    True indeed!
    I would imagine that the highlight strength could be adjusted given the complexity of the software. I know it is something I'd like to be able to do.
    Cheers.
  • ben98120000ben98120000 Posts: 469
    In DS, go to Windows - Panes (Tabs) - Tool Settings. There you can change Node Highlighting Draw Style to Bounding Box Only (removes the highlights) or you can reduce Active opacity to make highlights less visible.
  • Richard HaseltineRichard Haseltine Posts: 112,275
    Note that this has been moved to the new Draw Settings pane in the 4.8 beta.
    Ah!! That's what I was searching for!! I must have unintentionally changed that setting at some time when I was playing with those settings.
    Thanks to everyone!
    Cheers
