Redacted
cridgitcridgit Posts: 1,765
edited December 2022 in Daz Studio Discussion
​Redacted
Post edited by cridgit on
  • You could always type Legacy in the filter field, seelct all, make sure there were no items iwth Legacy in the name, and use the right-click menu to Hide Selected.
  • MelanieLMelanieL Posts: 7,904
    How are your download filters set? I unchecked "Daz Studio 3", "Daz Studio 4" and "Daz Studio Legacy" and all the "Poser" checkboxes - I just left "Daz Studio 4.5" checked (also apparently "Daz Studio 5" which I assume is for future use?!)
  • cridgitcridgit Posts: 1,765
    edited May 2022
    ​Redacted
  • It should be able to, based on tags, but a while back something happened to the tags on soem of the products and a bunch started appearing regardless.
    edited May 2022
    ​Redacted
    edited February 2022
    You are right about the filters - I didn't have DIM open at the time (it takes an age to load for me because I have such a massive list of products) so I browsed the ini file it uses instead. I have DIM open right now. The unchecked field called "Daz Legacy" in the .ini fie is (I think) the one called "Daz Studio (<3)" in DIM, so uncheck that too. Also "DSON Importer for Poser" is unchecked for me.
    I just see 3 items listed as legacy versions with those filter settings - they are all (erroneously?) flagged for DS4.5 too..
    Post edited by MelanieL on
  • frank0314frank0314 Posts: 15,120
    report them so the tags can be updated
    Done.
