Redacted
cridgitcridgit Posts: 1,765
edited December 2022 in Daz Studio Discussion
​Redacted
Post edited by cridgit on
  • barbultbarbult Posts: 27,391
    Yes, apply a dForce weight map.
  • charlescharles Posts: 866
    You can do weight maps, but also goto into geometry tool setting, and see if the ponytail is a seperate block of geometry, a submesh. If so hide it by clicking the eye.  Do your dforce and then unhide the tail. It should be where it orignally was. But something to keep in mind when dealing with dforce on objects with subs, is that you want to put the 0% influence on as much as possible otherwise it's probably going to get wonky.
  • cridgitcridgit Posts: 1,765
    edited May 2022
    ​Redacted
