Able to set fully green alien eyes back to genesis default eyes?
VicSVicS Posts: 1,273
edited January 2022 in Daz Studio Discussion
[Able to set fully green alien eyes back to genesis default eyes?] Good to know also for M4 and V4 or any charater, will it be the same for all? thanks
Edited for Please put your question in the post body and the title - Daz 3D Forums
  • Usually characters include materials for the eyes as separate presets/poses.
  • NorthOf45NorthOf45 Posts: 5,915
    edited January 2022
    Select the figure in the scene. Find the materials you want to use. Not a problem if there are no separate eye textures, you can select which surfaces are changed. Go to the Surfaces tab and expand the surfaces tree so that you can see them all. Multi-select all eye surfaces (depends on the generation, but include things like Iris, Pupil, Sclera, Cornea, Lacrimals, Moisture, etc., that are obviously part of the eye that you want to restore. Go to the material preset you want to use and hold the CTRL key when you apply it to get the load Options dialog (the CTRL key often gives an options dialog for different types). You have two choices to Apply: Surfaces -> Selected, and Images -> Replace.
    Post edited by NorthOf45 on
  • VicSVicS Posts: 1,273
    Ok thank you
    How about turning the whites of the eyes different colors to create the alien eyes myself -I can't find what to choose for that in surfaces
    That would be the Sclera. You will have to go into the Surfaces pane to get to it.
    Thanks!
