Tentacle posing
I was wondering if anyone had any tutorial links or easy ways that make posing tentacles easier without using the given morphs or bending the bone links one by one.
For instance if I wanted to wrap a tentacle around a pole, what would be the best way to do that?
  • HylasHylas Posts: 5,349
    edited January 2022
    1) To select the entire tentacle, right click on he first link of your tentacle. Select -> Select Children
    2) Go to the Parameters tab. Make sure All is selected. Use Bend/Twist/Side-Side to change all links at once.
    3) Alternatively, use shift to only select some links of your tentacle.
    4) Same story: Go to the Parameters tab. Make sure All is selected. Use Bend/Twist/Side-Side to change all selected links at once.
    937 x 886 - 98K
    948 x 867 - 136K
    909 x 852 - 88K
    922 x 874 - 121K
    Post edited by Hylas on
  • FenixPhoenixFenixPhoenix Posts: 3,259
    You can also select the bones you want to move and use the center sphere in the Left upper corner of your viewport to bend and twist. So:
    1. Select the bones
    2. Click on the sphere and drag your mouse
    Alternatively, you can use the three circles (red, green blue) to also bend, twist and rotate.
  • clay392clay392 Posts: 11
    Thank you so much, this is exactly what I was looking for!!
  • Thank you so much for posting this. I was just about to throw in the towel because I couldn't figure how to make a curve gradual!
    Jenn - Odyssey Graphic Designs
