Shader Problem
GuruvarGuruvar Posts: 344
Hello,
I'm creating a custom character (not using Genesis or other Daz formats). I was playing around with Shaders for the eyes, and I can't seem to get them to revert to their base values (except in preview mode). When I render, I get this. Any suggestions?
I tried applying other shaders to it, including the Base shader, but the eyes still show up as purple.
359 x 413 - 110K
  • Richard HaseltineRichard Haseltine Posts: 112,275
    Check to see if there's an eye surface or similar material over the eyes, which you aren't modifying.
  • GuruvarGuruvar Posts: 344
    Hello Richard,
    Sorry for the delay in response. Unless there's something hidden, I can't see any surface or material obstructing the eyes. The material in the preview port looks fine, also. It's just when I render it that I get the purple effect.
    721 x 499 - 126K
    Which figure is it? The issue could well be in the specular or reflection settings, as well as the base diffuse.
    Hello,
    It is a custom figure I rigged with Make Human. I just fooled around with the Specular and Reflection settings and it has zero effect. Everything was fine until I started playing around with the Shaders earlier today. Somehow I mucked it up when I applied a Shader.
    I'm at a total loss. I actually recreated the character from scratch and I'm STILL getting the same problem. I bought the DSON Editor to try to get into the nuts and bolts of the file, but I can't see anything wrong.
    Does anyone have any idea as to where I could begin to look for a solution?
    Okay, I think I know what the problem is... will post results of my findings in case anyone else has the same problem.
