posing - enable limits for everything
in New Users
Something went wrong and absolutely every parameter in posing disabled the limits. How do I not go crazy including dozens of limits manually?)
Check that Edit>Figure>Limits>Limits On is actually enabled.
it didn't work
In the scene tab expand the figure and select every bone, try again!
It doesn't work for expressions. posing tab
Ah...select the figure, go to the parameterspane/posecontrols. Rightclick the tab and go to edit mode. Now you can select every pose property, rightclick again and there is an otion to set limits on for selected properties (or along those lines). Finally rightclick and exit edit mode.
Thank you so much!
