Redacted
cridgitcridgit Posts: 1,765
edited December 2022 in The Commons
​Redacted
Post edited by cridgit on
  • nicsttnicstt Posts: 11,715
    edited December 2021
    It can be done.
    Export as obj; import into 3D package (I use Blender).
    If you're using strands, select the geometry editor before exporting. Make sure you export any obj at base resolution.
    As you can see in the image, a custom morph I made for a dforce strand hair (Dforce Soft Curls): applied and not.
    Edit:
    If an item has a differences in left and right, try scaling on the X asix to -100, it might work; it does, just tried. That might give you what you need.
    1334 x 1021 - 232K
    Post edited by nicstt on
  • cridgitcridgit Posts: 1,765
    edited May 2022
    ​Redacted
  • I didn't know you could create morphs for strandbased hairs or the geometry editor trick either
    if I export with line tesselation they are huge!
