Parameters Zero Animation Changes Fig
I want to simply clear the animation...return the figure to a starting pose...but every time I "Clear Animation" in the Parameters tab it erases all my morphs and resets the fig to the original figure appearance. Any better ways of erasing all animation from a figure?
Post edited by Deke on
You need to memorize the shaping first. Edit -> Figure -> Memorize -> Memorize Figure Shape.
Is there a good resource in understanding these options? Zero figure, Clear Animation, Restore Pose....all these terms imply very similiar things. For example, I'd like to be able to keep a characters shape and morphs, but zero the entire figure so it's back to a standing T pose (essentially erasing any posses or animation keyframes).
Edit - Figure - zero figure pose
What I always do when I want to zero a figures pose but not the entire figure (so: it should not mess with its position and all that) is to use the option "Zero Selected Items" (I also assigned a shortcut for this). Now, the trick here is not to select the full figure but only its limbs, to do that you're also going to need the scene option "Select children" (which you should also assign a keycombo to for easier usage).
Then:
Low and behold: the figure assumes the default zero-t pose yet without moving to its default position within your scene. IMO this is the best procedure for all this.
