Saved Files Problem
I just discovered a problem. I've found items listed in the Saved Files category that should be under other categories, such as Wardrobe or Materials or someplace else. The artists creating the content are putting things in the wrong folders so they're falling into the wrong categories. Also, I think DAZ isn't quality checking that these things are properly packaged so they show up in the righth place. I've put in so many tickets for this sort of thing that I'm getting exhausted doing so. I just thought I would give a heads up that you might have some items in the Saved Files category that you may not know are there. I could go in and move things to the right folders, but I shouldn't have to do that. They should already be in the right folders and show up in the right places. Just saying.
  • TaozTaoz Posts: 10,377
    edited November 2021
    Saved Files category?  Where is that?
    Never mind, can see it's in Smart Content (which I don't use).  I wonder where these files would end up in Content Library?
    Post edited by Taoz on
  • LeanaLeana Posts: 13,641
    From what I've read, metadata for smart content is actually created by Daz, not by the PA.
    It's a category, it will be used in the Categories cotnainer in the content Library pane, in the Presets tabs of relevant property panes, and in Smart content when the filtering permits.
    OK, thanks!
