Gen8 loading
in The Commons
Genesis figures take a long time to load, then I get a 'duplicate IDs' error message. Is there a fix for this?
Help>Troubleshooting>View Log File, then search for Duplicate. That should show the full error emssages, which will name one of the duplicates - with luck the path given will identify the character. The issue is unlikely to be with that character alone, though it can happen, but rather a clash with another character or morph set that uses the same name - you may be able to deduce which from the names. You could uninstall oen of each pair, you can edit the files to change one of the names, but either way if any involve products from the Daz store they should be reported.
Thanks. Unfortunately, the path given contains a folder that doesn't seem to exist. Hidden files are visible.
Log file shows "Duplicate formula found linking xEnd & Naomi Head in /data/DAZ 3D/Genesis 8/Female/Morphs/Anain&Belladona/Naomi/Naomi Head.dsf.", but Anain&Belladona is not there.
I'm not sure what to do now.
Have you checked all of your content directories, including /data/clouds/1_57451/data/DAZ 3D/Genesis 8/Female/Morphs/Anain&Belladona/Naomi/Naomi Head.dsf in case it was installed through Connect?
