Obj
Hello ,a have a question how i can register obj shoes in Daz for genesis ???
  • margravemargrave Posts: 1,822
    "Register"?
    Not sure what you mean.
    If you mean turn them into conforming clothing, then you position them over the feet and then run the Transfer Utility (Edit -> Figure) to copy the skeleton from the Genesis figure to the shoes. The autogenerated weight maps will probably look terrible though, so you'll almost definitely have to adjust that with the Node Weight Map Brush tool.
  • frank0314frank0314 Posts: 15,089
    Moved to Daz Studio Discusssion since it's not a product suggestion.
  • margrave said:
    "Register"?
    The imported model has to line up with the feet, if it doesn't check that you used the correct import settings for the model (OBJ dosn't have an inherent scale or orientation) and if that fails adjust to line up and then export as OBJ under a new name, then reimport (that bakes-in the changes you made to the model).
    If the item has high heels then yes, you are likely to need to edit the weights (at least) but if the heels are fairly low then the generated weights may well be acceptable.
