Texture gamma
TofusanTofusan Posts: 28
Is there a way to change the gamma value of texture by script?
  • rbtwhizrbtwhiz Posts: 2,485
    edited July 2015
    // Get the image managervar oImageMgr = App.getImageMgr();// Define the desired gammavar nGamma = 2.2;// Get or create a DzTexture for the image; set gamma if createdvar oTexture = oImageMgr.getImage( "Absolute/path/to/image.ext", nGamma );// If we have a texture and its gamma is not the gamma we wantif( oTexture && oTexture.getGamma() != nGamma ){ // Set its gamma to the desired value oTexture.setGamma( nGamma );}
    -Rob
    Post edited by rbtwhiz on
  • TofusanTofusan Posts: 28
    var nGamma = 2.2;
    -Rob
    Thank you very much. :D
  • dakkuuandakkuuan Posts: 305
    Is there a way to check a particular node for diffuse textures that aren't at 2.2?  This is probably a basic question but I'll ask since I'm new to Daz Scripting.
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Once you have the map oTexture.getGamma() will get the gamma. For getting the maps, see http://www.daz3d.com/forums/discussion/57229/
    -Rob
    But how do you know which channel to set the gamma value? If you want only the Base Color? Or if you want only the Translucency Color?
    Thnx Rob
    -Rob
    Thnx Rob
    You'd get the image from the property, then use Rob's code to get its gamma.
