Need to create a variety of characters...
From short to long, slender to over-weight, skinne to massive muscled. I'm not looking for subtlety but rather extreme character features. Faces as well as build.
Is there a add-on that can do this? There is a shape-shifting add-on here but from screenshots it seems too subtle.
Any suggestions would be appreciated.
  • You can generally relax or remove the limits on morphs - clicke the gear icon on the sldier>Parameter Settings, or right-click to put the Parameters pane in Edit Mode and then you can multi-select sliders and adjust them from the right-click menu; note that you will probably then have to do the same for thr entries listed in Sub Components at the bottom of the dialogue.
    Do bear in mind, however, that extreme adjustments are likely to stretch or distort the texture maps
  • GordigGordig Posts: 10,799
    Shape Shift is good, but if you're going to be dial-spinning characters from scratch, the first thing you'll need is the basic Daz morphs (male head/body, female head/body), and maybe Body Mixer if you want to, for example, have an athletic lower body on a tubbier upper body. For the head, 200 Plus.
  • marblemarble Posts: 7,500
    I use Musculature a lot too. I had to wait until there was a sale but the moment there was I grabbed both. I already had the same for G3 F & M.
