Keyframes Not Replicating?...
I'm not sure how to word this but I'll try my best :P I basically have an animation that is 30 frames long. Across the animation I wanted to reset the expression on a character but couldn't figure it out, I ended up opting for locking the head rotation in place and using CTRL+E to reset the expression per frame. However, now when I try to get a new expression on frame 1, it only set's it for that first frame and doesn't do it for any others, is there any way to make it so if I change something on frame 1, it changes it for every other frame as well? it seems to do it by default when I start the animation from scratch but once I get further into the animation it seems to just stop...
That sounds as if there are still keys, for the zero values, un some succeeding frames. You need to actually delete the later keys for the value at frame 0 to propagate. Select the keys (most readily by marquee drag in the dope-sheet area) and then deleet by right-click or by the key icon with a - in the buttons along the bottom.
