QQ on the teeth as shown in the Acicia Bundle for G8F promo
In the Acicia bundle promo, you can see fox/cat like fangs:
Does anyone that has the bundle know whether they're actually part of the bundle, and if so, whether they can be applied to other G8F characters as well?
(And if they're not, any idea where those teeth *do* come from?)
  • MimicMollyMimicMolly Posts: 2,376
    Those fangs are part Acicia's head morph, so they can't be used on other characters, unless you mix her morph with them. (I know this because I wanted normal human girl renders of her and found myself using other fang morphs at negative values to reduce the appearance of her built-in fangs.)
    Ok, then I'll need to keep experimenting with other fang morphs... Thx!
  • GordigGordig Posts: 10,816
    If you have Shape Splitter, you could try to extract the teeth morph, whether for Molly's purpose or the OP's.
     Interesting... Seems pretty complex though... (And not the cheapest plugin either...)
    edited November 2021
    If you are looking for fangs, you can just pick up any vampire G8F (probably a DAZ Originals one since those often go on sale), that says it has Fangs Apply/Remove in the product description. This product also has fang options for G8F and other morphs (there is a separate male version too) https://www.daz3d.com/sy-fantastical-features-genesis-8-female
    Post edited by MimicMolly on
    I actually just grabbed this one in the 50/60/70% FLAH sale with a few other items that aren't on sale (or as deeply discounted) that often, according to Daz Deals plugin...
  • margravemargrave Posts: 1,822
    You don't even need a product. You can remove vertices from a morph natively inside Daz Studio.
    Duplicate the morph with the fangs and flag the duplicate as Favorite, use the Geometry Tool to select the vertices you want to remove, then right click and choose Morph Editing -> Clear Selected Deltas from Favorites.
     Hmmmm.... Interesting, might have to take a look at that...
  • Hi @daisuki.nekomusume,
    I own the bundle and while @MimicMolly is correct, you can assign a very low value to Acicia's head morph (e.g. 0.001%) and drag the Acicia Teeth slider all the way up to 100%.
    Cheers.
    1132 x 1452 - 1M
    Cheers.
    Sweet... I may need to test that once I buy the bundle... Just hope it's gonna be on sale some time in the near future...
