full white (or any other color) sheet in Bryce 7
QykoQyko Posts: 1
edited February 2015 in New Users
Hello,
Is it possible to help me with the following problem.
I want to print only the rendered obj to a white sheet of paper.
(Without the preset sky an ground plane).
I found a way to have a white sky.
But I can not find how to suppress the preset grey ground plane.
(I also want it white or black).
Bryce 7.x Pro.
Thank you very much.
Post edited by Qyko on
    You will need to do it in two renders. One you render normally, the 2nd render you select the object that you want to show and then use the render options to make a mask render
    Then you can use the mask to remove the background in a paint program that supports using layers.
    175 x 470 - 65K
    265 x 179 - 45K
  • hacsarthacsart Posts: 2,037
    Select the ground plane - press delete.
    Click on the triangle next to 'Sky and Fog" - that will open the Sky Library. Look in the Backdrops library - there's one called Simple White Background. You may need to adjust the lighting..
  • QykoQyko Posts: 1
    @chohole
    @hacsart
    The second solution gets my preferences.
    Kool! Thanks :-)
