3DConnexion Plug-in Error? Crashing during Render process?
I recently downloaded and started playing with this just last night. Created two images with no problem (three if you include one from a tutorial) and yet this image seems to be giving the program fits? Am I missing something that I have done incorrectly?
*** Scene Cleared ***
Loading plug-ins:
aniMate2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzassetiofilters.dll
dzautofit.dll
dzautoriggerbasic.dll
dzautoshaderbakeractions.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcontentdbeditor.dll
dzcontentlibrarypane.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdelightrenderer.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzgoz.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmanualshaderbaker.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzmorphloaderpro.dll
dzobjexporter.dll
dzoptitexclothbasic.dll
dzpolygongroupeditortool.dll
dzprimitives.dll
dzpropertyhierarchyeditor.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzrslshadercompiler.dll
dzsavefilters.dll
dzscriptedrenderer.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dzshadermixerbase.dll
dzshadermixergui.dll
dzsmartcontentpane.dll
dzspotrendertool.dll
dztextureatlas.dll
dztransferutility.dll
dzu3dexporter.dll
dzweightmapbrush.dll
dzwinvideo.dll
sdk_sceneinfopane.dll
dzdrawstyles.dll
dzmimicbasic.dll
dzpowerpose.dll
Could not activate aniMate 2 evaluation. Plug-in disabled.
Error writing author data!
Total class factories: 1339
Creating Script Engine...
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
That is just a warning, not a real error, and it comes up for everybody I think, I certainly get it.
Can you tell me what you are rendering when the program complains, and an idea of what OS you are using, and how much RAM you have. Also are you using the 32 bit or 64 bit version?
+++++++++++++++ DAZ Studio 4.7.0.12 starting +++++++++++++++++
Platform bits: 32
Qt Version: 4.8.6
OpenSubdiv Version: 2.3.5
Running on Windows 8.1, Build 9200, No Service Pack Installed
CPU Information:
CPU String: AuthenticAMD
CPU Brand String: AMD A10-6700 APU with Radeon(tm) HD Graphics
Cache Line Size = 64
L2 Associativity = 8
Cache Size = 2048
Stepping ID = 1
Model = 3
Family = 15
Extended model = 1
Extended family = 6
CLFLUSH cache line size = 64
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Hyper-threading Technology
Physical Memory:
Total: 2.9 GB (3179651072)
Avail: 600.1 MB (629305344)
Virtual Memory:
Total: 1.9 GB (2147352576)
Avail: 1.8 GB (1961242624)
Current Memory Usage: 80%
Current DateTime:
Loc: Mon Feb 16 21:56:37 2015
UTC: Tue Feb 17 04:56:37 2015
Temp Data:
Location = C:/Users/Danielle/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 931.1 GB (999835037696)
Disk Avail: 736.3 GB (790633660416)
Locale: en_US
No translator found.
I dont have the specifics on what I was rendering aside from they were two basic models, male and female, using the ac_doorway environment. I can load it back up as I saved it in case it did start crashing while I was rendering.
It looks like you have less than 3 GB of RAM, and you are using the 32 bit version.
This may limit the amount of figures, and other items you can have in any one scene. It certainly sounds like you may be running out of memory. If DS crashes, the next time you start it, look at the very end of the log file to see if there are any 3Delight error messages.
You really need to add more memory I think.
I've been having much the same problem, and yes, I'm running a 32-bit Windows 7 machine with only 2 GB of RAM (hey, it seemed like a lot at the time!). Basic OpenGL seems to work OK, but with Intermediate OpenGL or 3Delight, yeah, with a lot of props or more than one figure in the scene it crashes.
Are there specific render settings which might still let it work? Thanks.
If you look in Task Manager with DAZ Studio loaded, how much memory is there left for DS to use?
With Win7 loaded, and DAZ Studio, you may have very little memory left to play with, so the number of figures in your Scene, the lighting used, and any hair or transparency maps used will have very little memory left to work with.
Texture sizes will also be important in that case too, and the first thing that DS does when using the 3Delight renderer, is to run a program called TDLMAKE.EXE, which creates a lot of smaller textures for use in your render. It is similar to mip mapping in games engines, and that uses up memory as well.
There is no render setting that I know of that can help with memory issues as such. What do you have in the Scene which crashes, how many figures, clothing etc.?
