How do I Apply a .hdr file in Daz 4.15?
OMG! It's all gone. All the environment settings for you're renders is gone. Also the environment map where you apply a .hdr file. So, now how do I get a .hdr file into it?
Any help would be appreciated. Thanks ahead.
Post edited by music2u4u on
Sounds good...one problem...there is no environmental section in the render settings. Always has been until now. Don't want to make my own environment, thats why I got other .hdr downloads. Suppose to set it up automatically I hear. Good, but what if I want to change something? How do I do that with no settings? Very confusing.
You would not have an Environment section in the Render Settings pane if your scene do not have an Environment Options node
Step 1: Create --> New Environment Options Node
Step 2: click the newly created Environment Options in the Scene tab
Step 3: Click the Parameters pane
Step 4: scroll to the bottom of the Parameters pane and click "Environmemt"
Step 5: click "Dome" under the list
Step 6: find the Environment Map below Environment Intensity. It should be the default DTDHR-RuinsB-500.hdr
Step 7: click the default hdr to change to your preferred hdr
It's confusing, but if you have to use 4.15 for the new features like PBR shader, you have no choice but to scramble through the panes to find the answer
Supposedly loading pre-4.15 scenes should already create an Environmental Options node and a Tonemapper Options node, so you directly go to Step 2.
I have seen both of those in the scene tab and wondered what they were for. Now I know and thanks for the help!
