how do you change the color of the back ground color of the menus,
in The Commons
how do I change the border of Daz, where the menus and lists are, it suddenly turned white
The interface should never be white. Did you update DAZ Studio while it was still running maybe? Because that's what happens when you do that. You probably want to close DAZ, look in the task manager and make sure it's done. It can take several minutes depending on what you were working on last. Once you're absolutely sure it's not running in the background then reinstall DAZ Studio and it should be fixed.
Close normally and use task manager to make sure it's closed, actually closing through Task Manager might compound the issues.
