daz Render Engine Problem.
I receive this banner every time I try to render Iray in DAZ Studio 4.15.
275 x 95 - 22K
  • I have no idea what the problem is. All was going well till an hour ago. I have also uninstalled DAZ Studio and reinstalled it. Cheers
  • kyoto kidkyoto kid Posts: 42,515
    edited October 2021
    ...did you quit a render while it was still loading to the GPU (Iray) or optimising the scene (3DL)?  That is usually when I've seen it.occur
    Post edited by kyoto kid on
  • Which render engine is it (Iray is the default)? What Drawstyle is the Viewport using?
  • aedonixaedonix Posts: 40
    I'vce had this happen several times.  Aklways ended up having to kill Daz in Task manager, even if the program appears top be closed it still lingers there.
  • I have run into this error message with Iray render after disabling 3dlight render in the plugin setting. Might not be what causes it for you, but just one possible reason.
  • I've had this happen whenever a render crashes.  There's no way to clear it without killing the process in Task Manager.  I've reported this problem to Daz but never received a solution.  I take it to mean they don't know.
