Transfer Utility Problem
Panic CodePanic Code Posts: 40
So I created a piece of clothing in Zbrush. I made sure to zero out EVERYTHING on the model. Hit GoZ to bring in the clothing to DAZ. Made sure the clothing fit right and exported the clothing and then reimported back into DAZ. I changed the cothing.obj parent to genesis 2 female. Now I used the transfer utility to make the clothing move with g2f. Here's my problem, whenever I use the transfer utility it moves the clothing.obj in front of g2f. It literally comes off and to the front. Any suggestions?
  • DigiDotzDigiDotz Posts: 515
    Have you tried not parenting the clothing and running the Transfer ?
  • Panic CodePanic Code Posts: 40
    Just tried it. Same outcome.
  • Richard HaseltineRichard Haseltine Posts: 111,315
    So the zeroed clothing lines up with the zeroed figure?
    Yes. After I'm done in zbrush and hit GoZ, the clothing matches up. And the same with export/import of the obj. Its after I use Transfer Utility that the clothing decides to float in front of G2F.
    What are you settings in Transfer Utility? Are you sure that the root node is zeroed on the figure - it should be standing on the origin, with the slightly heavier lines on the floor grid crossing under it.
