Zbrush dynamic simulation problem
Hello! Another strange issue I have while trying to use dynamic simelation in Zbrush.
Basically it works but objects never touch the body, the always interact at some distance.
Even if I put object closer once I move it it jumps at that distance again.
1750 x 1141 - 231K
  • galiengalien Posts: 150
    By default, the inflate value for the collision volume is set to 1.  Try reducing it to something like 0.1 or 0.2.
  • mashvimmashvim Posts: 16
    edited September 2021
    Thank you! Now it works perfectly.
    Post edited by mashvim on
  • And maybe you could help me with one more problem.
    When I create come clothes in ZBrush I can't fit it to my model, it's parented and rigged, it moves but it placed lower than in should be.
    In this example I made a simple swimsuit (just extracted mask), but after Transfer Utility it goes down :(
    1344 x 1776 - 238K
    How did you get the mesh in and out of Daz Studio?
     I use bridge, File>Sent to ZBrush and in ZBrush I use button GoZ to send it back. But also you can export it as *.obj file and work with it and then inport it back.
