• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Recovering high resolution/"ruined" morph shapes
gmm2gmm2 Posts: 101
September 2021 edited September 2021 in Blender Discussion
We probably all know that creating a custom character with morphs in DAZ, exporting that shaped figure as an OBJ, then importing that shape through Morph Loader Pro is a pretty standard procedure. The two major caveats (at least with the Genesis 8 figures) are exporting the figure in base resolution and deleting the default eyelashes.
I know the frustration of spending time working on a custom character and accidentally exporting it in high resolution or forgetting to delete the eyelashes, seemingly ruining all that work. I don't know if anyone else has figured this out before me, but there are fortunately two fixes that can be done in Blender. I've only tested this with Genesis 8 Male and Female (not 8.1), but I see no reason it wouldn't be universal.
To fix a high resolution shape:
  • Import the OBJ into Blender, making sure to select Keep Vertex Order.
  • Add the Decimate modifer to the object. Select Un-Subdivide as the method, and increase Iterations to 2.
  • Apply the modifer.
  • Export the object as an OBJ, again selecting Keep Vertex Order.
The shape should now be able to be imported through Morph Loader Pro without issue.
To fix the eyelashes:
  • If the figure was exported with materials, simply go into Edit Mode, select the eyelash materials, and delete those faces.
  • If there are no materials, the eyelash geometry wil have to be deleted manually.
Didn't see anything about this when I searched the forums, so maybe it can help someone.
Post edited by gmm2 on September 2021
  • Richard HaseltineRichard Haseltine Posts: 112,006
    September 2021
    This isn't good practice anyway - if you bake all the component morphs into one then you lose any corrective morphs and joint adjustments connected to the component morphs. It is better to create a single slider for the morph and then use ERC Freeze to link the component morphs to that.
  • gmm2gmm2 Posts: 101
    Huh? I think we're talking about the same thing. Adjusting the joints to the dialed-in shape that was loaded through Morph Loader Pro, and then running ERC Freeze, would happen after what I'm talking about. I've done this dozens of times and never had to worry about corrective morphs being an issue, specifically because they're baked in (if they're present at all). The thing I was talking about was how to correct an OBJ so that process can even begin in the first place.
    September 2021
    By corrective morphs I meant things like an adjustment so that the eyes close morphs still close the eyes in their modified form, or to avoid a nasty crease when the arms bend - those can't be baked in as they are required only when the shape is applied and some other shape or bend is also applied.
    In any event, it isn't a good diea to encourage this practice as the results cannot be shared with others.
    September 2021
     I'm really not understanding why corrective morphs are an issue here. If they're required at all, then they can be remade or made from scratch to suit the new morph. They're not ultimately relevant to the process I described; it will work whether they're there or not.
    And certainly the results could be shared. If a morph was, for example, created in different "chunks" (like sculpting the body in multiple areas) and then loaded and applied all at once in DAZ, that new shape created from those multiple morphs could then be exported and reapplied as a single morph. If the mistakes I mentioned in exporting happened, the process I described will fix them.
    Even if they couldn't be shared, it would still be useful for personal morphs if those errors occurred.
    September 2021
    They can't be shared if they are built from other people's or vendors' morphs (depending on the license terms), which seemed to be what you are discussing. If you are building the individual morphs and then combining them then that is another matter.
    I was speaking generally. Of course using morphs without permission to make another one wouldn't be allowed to be sold. I wasn't intending to imply anything to the contrary.
    The only thing I was getting at with this thread was that this process works to recover an OBJ file intended to be used as a morph through Morph Loader Pro that was saved in one of two incorrect ways. I thought it was neat that it worked and thought I'd share since I didn't see that anyone else figured it out and maybe it could help someone. I just wanted to be helpful.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
