Compression artifacts
I'm running Big Sur and the new DAZ Studio. I'm getting artifacts on my texture rendering, I've turned the SSS to mono and fiddled with something in the render settings that dealt with pixelation. Last night I read here that there is a way to turn off the compression and that might work, but for the life of me, I cannot find the tab to do this. Can someone help an old lady out?
Thank you,
Denise
  • margravemargrave Posts: 1,822
    Render Settings, Advanced tab. Just set both the medium and high compression to be larger than the textures in your scene. 8200 is a good value, since 8K textures are 8192 pixels.
  • dvitoladvitola Posts: 136
    thank you so much, margrave!
  • PadonePadone Posts: 4,400
    medium you can use, it's just high that's causing artifacts
