dForce simulate error
Today I created the scene as usual, and then started to simulate dForce, but it threw an error
2021-09-19 00:12:19.864 WARNING: ..\..\..\src\dzdynamicsengine.cpp(426): Using device: NVIDIA GeForce RTX 30902021-09-19 00:12:20.067 Found 135 unused vert(s) on the geometry of node "Tifa G8.1F". Removing unused vert(s) from sim.2021-09-19 00:12:22.170 Spring(1590, 1591) of node "Elise Coctail Dress G8F" extended: rest length < collsion offset (0.159833 < 0.20001)2021-09-19 00:12:22.171 Spring(1814, 1815) of node "Elise Coctail Dress G8F" extended: rest length < collsion offset (0.170162 < 0.20001)2021-09-19 00:12:22.172 Spring(1821, 1822) of node "Elise Coctail Dress G8F" extended: rest length < collsion offset (0.19524 < 0.20001)2021-09-19 00:12:22.182 Shortest spring had length: 0.1598332021-09-19 00:12:22.317 WARNING: ..\..\..\src\dzdynamicsengine.cpp(3293): ERROR: clFinish (-36)
I tried restarting daz, restarting the computer, changing other clothes, and changing other characters, but the problem was not solved, and the error was similar to the above. How can i solve this problem?
Try seleting the dForce item, select all its surfaces in the Editor tab of the Surfaces pane, and set the Colision offset to 0.125
