Invisible, undeletable keyframes...
mtasteritimtasteriti Posts: 12
edited September 2021 in Daz Studio Discussion
This is a new problem that just popped up out of nowhere, and I've never had it before. Whenever I delete a keyframe on the timeline, the keyframe disappears from the timeline and appears to be deleted, but the animation plays as if it's still there whenever I play it or scroll through it. I refresh, and the keyframe still appears to be gone, but its effect remains. So now what I have is essentially an invisible keyframe that I can't delete, and it's making animation pretty much impossible. Can anyone help me? Thanks.
Post edited by mtasteriti on
  • What you have to do is go to the "Types:" dropdown menu on the timeline and select TRSOAH (check all the boxes). By default some keyframes are not visible. Not sure why this is the default setting, but I suppose there are some instances where you wouldn't want scale or rotation frames to be viewable for instance. Just change it and you're good to go.
  • That fixed it, thanks so much!
  • Also, make sure that you are not using a Pose Control on the figure to affect a bone.
  • Thank you for this!  It works!
  • cheardcheard Posts: 145
    Almost three years later, I had similar confusion, but found this thread and resolved everything. Thanks again, @st3ph3nstrang3!
    Yes has run into this before, I know an reason is if you manges to changes the frames pr second reducing number of frames.
    On earlier version of studio I belive changing the range would change the fps for some reason, solution was to change the total.
    This bug has been fixed long ago.
