OBJ Import Bug.
lorddayradonlorddayradon Posts: 597
1.Loaded daz,
2. opened window 'figure setup'
3.add geometry (lets me select an obj)
4... this is what I get, how do I fix it so that I can adjust the import options?
Cursor has the constant circle loading in bg with the arrow, going to edges of the import window does NOT show resize arrow, and trying leads to nothing. Cancel and try again leads to same result.
1927 x 1057 - 257K
Post edited by lorddayradon on
  • felisfelis Posts: 6,658
    Is this happening with any obj?
  • AscaniaAscania Posts: 1,856
    You move the cursor to the bottom of that dialogue window and pull it larger.
  • lorddayradonlorddayradon Posts: 597
    edited August 2021
    re:
    Every one I try
    edit:  Hitting accept anyway leads to the image below.  My concern; what options if any are selected/not selected with respect to add geometry (are there any?)
    1182 x 1046 - 117K
    What happens if you try to import it through File > Import. Can you then get to the setup.
    Yes, the same window appears, in the same truncated size, but going to the edge I get the resize arrows, and it resizes successfully.
