Lights
Does anyone happen to know a light set that contains good mesh lights?...its important that they be mesh lights.
  • Good is surely going to be context dependent - a good set for lighting a dungeon is going to be less good for a children's party scene, a good set for an office will not suit a romantic dinner.
  • IceCrMnIceCrMn Posts: 2,333
    You can make you own very simple.
    The short version is;
    1) Create>New Primitive>Plane
    Select new plane in the "Scene" pane
    2) "Surfaces" pane
    change "Emission Color" to anything other than black to "turn it on". Full White is a good place to start.
    "Two Sided Light" is "Off".
    Change Opacity to 0.0001 to hide.
    Change "Luminance Units" to kcd/m2
    Done, you have a basic mesh light.
    Some adjustments and fine tuning will be needed for your specific scene.
    Once you've had a chance to play with the basic ones you make yourself; you will know more of what you want from a commercial set.
    Don't be afraid to turn the knobs and move the sliders.
    It's iray, so you'll need to use the iray preview render to see the changes.
    File>Save as>Scene Subset and put a check mark next to the things you want to keep if you make something you like.
