Remove Fur
Is it possible to move or remove patches of fur from for example the fur of Dire Wolf for daz dog 8? i tried moving it with dforce simulation and deformers but it doesn't really work for me. i would like to remove part of the fur entirely too. does anyone know if that is possible?
  • Sky77Sky77 Posts: 820
    The only way I can think of doing something like that would be to assign different material properties to the areas of question.
  • Richard HaseltineRichard Haseltine Posts: 112,037
    It should, I think, be possible to edit the distribution map - but I've not tried.
  • ridanzswerdridanzswerd Posts: 10
    edited July 2021
    if i selected some surface areas of the dog with geometry editor, how can i give the surface a different material property?
    Post edited by ridanzswerd on
  • FSMCDesignsFSMCDesigns Posts: 12,858
    right click and you will get quite a few options. One will be the create a new material zome from the selected polys
    is that an option of the "strand based hair editor"? i never used that but i think it doesn't work here, i just get the message to select a node of strand based hair first.
  • GordigGordig Posts: 10,844
    There are one or two (depending on how the hair is set up) slots in the Surfaces pane for PS/PR distribution, and dropping opacity maps in those slots determines how densely the hair grows.
    edited August 2021
    Ok thanks for the answers. got some usefull infos. still need to work on it a little bit but might just not be possible to do it the way i want.
