how do i get hair to work with her head morphs : ( the ears are not separated....
AkuraAkura Posts: 41
edited July 2021 in Daz Studio Discussion
[how do i get hair to work with her head morphs : ( the ears are not separated....]
Edited for https://www.daz3d.com/forums/discussion/109161/please-put-your-question-in-the-post-body-and-the-title#latest and image size
    What morphs are activated when the shape is dialed?
    The product includes 13 ear morphs and if one of them is used with the shape, you could zero the effect on the hair (dial is hidden). Alternatively, if the ear morphs are not used with the shape, you could still try to eliminate the effect by dialing negative values for the hidden dials on the hair, just give the dial a value of 0.01% on the figure and you can find that dial afterwards also transferred to the hair.
  • AkuraAkura Posts: 41
    edited July 2021
    under head morphs using HFS Head 08 Alien gives that shap to the head..... the issue is the ears : ( the hair only suppose to cover the head not the ears tooo.....
    as you can see in the screnshot when i turn auto follow off, that happens D:
    457 x 354 - 61K
    738 x 455 - 175K
    Post edited by Akura on
  • LindseyLindsey Posts: 2,017
    edited July 2021
    Autofit is applying morphs to the hair based on the figure.  You need to dial back the morphs autofit is applying to the hair.
    1. Select the Hair
    2. Go to the Parameters tab and click on the Pane Options on the upper right and select "Show Hidden Properties"
    3. Select "Currently Used" and you'll see the auto applied morphs.  On my example the auto applied morph is "SB Ears Rabbit" and I just dialed it back that applied morph.  On your Hair figure, you'll see a similar auto applied morph, just dial it back and you'll see the hair drop off the ears.
    1935 x 927 - 534K
    Post edited by Lindsey on
    thank you ^^ it not working with this head morph very well as the top of the head still gets removed hmm will have to try a different morph setting
  • LeanaLeana Posts: 13,537
    Parent the hair to the head rather than fitting it, then adjust it manually so it fits the morphed head shape rather than relying on automatic morph transfer.
    thank you so much that actually worked ^^ better then i thought it would ^^
