Flip Pose
tomsfo1tomsfo1 Posts: 87
As part of my learning process, I am trying to flip a pose, say from leaning on the left arm to the right, but keeping the same pose. I read in the Forum I can do this with Symmetry (Shift-Y) . I changed the direction from Left to Right to Right to Left but nothing happened.
I tried various Transform options, still with no changes. I'm using DAZ 4.7, and a Gen2F and it was selected..
Obviously, I'm missing something. Any assistance is appreciated.
Tom
  • fixmypcmikefixmypcmike Posts: 19,743
    The options you want are:
    Nodes: Root (start from the root of the figure)
    Propagation: Recursive (go through all the nodes)
    Direction: Swap Left and Right (instead of copying just one side to the other, you want to reverse the two sides)
    Trunk Nodes: Mirror Y/Z Rotations (so if the center of the body is twisted, reverse the direction of the twist)
    Usually you will want the 3 rotations checked, and the translations and scaling unchecked.
  • tomsfo1tomsfo1 Posts: 87
    Thanks so much. That worked perfectly. I appreciate it.
    Tom
