This is most likely down to interpolations, trying to maintain a smooth transition between keys. The Timeline pane wil let you adjust the behaviour, and in the graph sheet will let you see how the value is changing.
You need to use the Timeline to change the interpolation type, or if you leave it at TCB adjust the values to behave as you want. Select the key in the Timeline (by default, TCB, it will have a T in a circle as its marker, then either use the button at bottom-right, next to the TCB text, or right-click on the key>Set Key Interpolation to change the type.
How to cancel this influence,thank you
Thank you very much. Let me have a try
