AMD 5700XT OpenCL kernel error
After updating my AMD drivers from 20.x.y to 21.6.2, Daz Studio asked me to re-compile the dForce kernels.
I click "Yes", it proccesses for about 10 seconds and gives an error "Error initializing OpenCL kernel."
The only OpenCL option for me is "AMD Accelerated Parallel Processing gfx1010:xnack-".
OS: Windows 10 Pro
GPU: AMD Radeon RX 5700 XT 8GB
CPU: Ryzen 5 3600
Daz Studio 4.15.0.2 Pro 64-bit
log.txt:
2021-07-07 18:29:21.348 WARNING: ..\..\..\src\dzdynamicsengine.cpp(426): Using device: gfx1010:xnack-2021-07-07 18:29:24.523 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(499): ERROR: clBuildProgram (-11)2021-07-07 18:29:24.523 WARNING: Source built for calcVertTriCollisionCollidePoint. Build log:lld: error: undefined hidden symbol: find_coplanarity_times>>> referenced by C:\Users\TNIS~1\AppData\Local\Temp\comgr-ba1c92\input\linked.bc.o:(calcVertTriCollisionCollidePoint)>>> referenced by C:\Users\TNIS~1\AppData\Local\Temp\comgr-ba1c92\input\linked.bc.o:(calcVertTriCollisionCollidePoint)Error: Creating the executable from LLVM IRs failed.2021-07-07 18:29:27.885 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(499): ERROR: clBuildProgram (-11)2021-07-07 18:29:27.885 WARNING: Source built for calcTriVertCollisionCollideFace. Build log:lld: error: undefined hidden symbol: find_coplanarity_times>>> referenced by C:\Users\TNIS~1\AppData\Local\Temp\comgr-a8fe32\input\linked.bc.o:(calcTriVertCollisionCollideFace)>>> referenced by C:\Users\TNIS~1\AppData\Local\Temp\comgr-a8fe32\input\linked.bc.o:(calcTriVertCollisionCollideFace)Error: Creating the executable from LLVM IRs failed.2021-07-07 18:29:31.629 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(499): ERROR: clBuildProgram (-11)2021-07-07 18:29:31.629 WARNING: Source built for calcEdgeCollisionCollideEdge. Build log:lld: error: undefined hidden symbol: find_coplanarity_times>>> referenced by C:\Users\TNIS~1\AppData\Local\Temp\comgr-0b36a6\input\linked.bc.o:(calcEdgeCollisionCollideEdge)>>> referenced by C:\Users\TNIS~1\AppData\Local\Temp\comgr-0b36a6\input\linked.bc.o:(calcEdgeCollisionCollideEdge)Error: Creating the executable from LLVM IRs failed.2021-07-07 18:29:31.640 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(351): m_isValid = false @ dzopenclkernelfactory.h, line 118 (after loading kernel members)2021-07-07 18:29:31.741 WARNING: ..\..\..\src\dzdynamicsengine.cpp(3625): Error initializing OpenCL!2021-07-07 18:29:31.741 Total Simulation Time: 11.32 seconds
  • After reverting back to the trusty 20.12.1 drivers, compiling the kernel worked liked a charm.
    So either AMD dropped their OpenCL support or some such, or Daz Studio managed to screw something up or both.
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Is this for the AMD CPU or the AMD GPU?
    20.12.1 are the GPU drivers, named as "AMD_Radeon_Installer_20.12.1" in my AMD/drivers folder.
  • karrnadkarrnad Posts: 0
    The same problem. AMD drivers 21.7.2
    OS: Windows 10 Pro
    CPU: Core i7 8700k
    I didn't find a solution. Only rollback to the old driver
  • This is still an issue, in case any Daz devs are monitoring this.
    If you want to be sure the developers see it please open support tickets https://www.daz3d.com/help
