2D Render
Hello, all!
I've tried everything I could think of to get skin effects similar to these, but I can't seem to manage it. Is there a particular render setting that I need or a special shader? Thanks in advance!
800 x 1067 - 593K
601 x 917 - 717K
  • TaozTaoz Posts: 10,401
    edited July 2021
    The second one looks like it's postworked in PhotoShop, you can get a lot of filters and actions that can do that, for example here:
    https://www.photowhoa.com/product-category/photoshop-bundle/?orderby=date
    https://webmaster-deals.com/1498-mega-oil-painting-photoshop-action-bundle.html
    The mermaid is probably a Poser render as the mermaid tail is Poser only.  Not sure what you mean by skin effect, but here's the same V4 character as the one used for the mermaid, converted to Iray with htis:
    https://www.daz3d.com/iray-converter-for-generation-4
    and with skin surfaces tweaked a bit to get that shiny look, if that's what you're after.
    802 x 930 - 952K
    Post edited by Taoz on
  • margravemargrave Posts: 1,822
    If you download GIMP (it's free), it comes with a filter library called G'Mic that has a bunch of artistic filters to replicate the digital painting look of #2.
  • KrzysztofaKrzysztofa Posts: 226
    Any suggestions on which parts of GMIC to use? I have it and it has a boat load of options.
    edited July 2021
    A few I like to use:
    Basic Render
    Illustration Look
    Dream Smoothing
    Pencil
    Combined
    (Illustration Look base layer, with Dream Smoothing set to Screen blend at 50% and Pencil set to Multiply blend at 75%)
    800 x 1280 - 1M
    800 x 1280 - 1M
    800 x 1280 - 936K
    800 x 1280 - 983K
    800 x 1280 - 2M
    Post edited by margrave on
  • GordigGordig Posts: 10,855
    Honestly, it doesn't look like a render at all to me; it just looks like a drawing.
    Could be.  Can be hard to tell these days with so many techniques and options.  Here's some test samples I did a while ago using PhotoShop actions on renders. First one in each set is the original.
    1448 x 933 - 282K
    1448 x 933 - 3M
    1448 x 933 - 3M
    1448 x 933 - 2M
    1860 x 921 - 3M
    1860 x 921 - 3M
    1860 x 921 - 3M
  • MartirillaMartirilla Posts: 193
    The free G'MIC is now available as an 8BF plugin, and can run anything that can handle that popular format of old-school Photoshop plugin. But, as you can see, you're still going to need some heavy postwork and overpainting to get something like the first two images. Multi-pass renders, layers and a pen-tablet are your friends, and trying to do it 'all at once' is going to look cheesy even with G'MIC to help.
